datamgmt
Jul 21, 2008Aspirant
Backup ReadyNas to ReadyNas with rsync and exclude lists
Hi, I have two ReadyNas that are successfully doing backups (between two sites) via rsync. There is one directory that we do not wish to copy over because it contains large, temporary media files (...
jleinbach
Jan 29, 2009Aspirant
Ian, Thanks so much. That's perfect. I never need the --links switch so that fix will be do the trick. I feel safe making an alteration as innocuous as that. I will actually need the exclude too ultimately and will probably use your approach to have a seperate file for the additional paramter(s), but for now just getting things going with removal of the --links switch will do the trick. It does seem (given how it is all implemented) that adding a text box to FrontView to allow for the manual setting of switches in rsync would be a trivial enhancement for them to implement. Maybe we'll see it in the next release. Thanks again.
