tommunday
May 27, 2015Aspirant
Backup remotely (not over LAN)
Hi, I've had my ReadyNAS a few days and I'm desperately trying to get it backing up remotely (i.e. not from LAN) - ReadyCloud will only backup from USER folder and only to root of NAS (really sophisti...
May 27, 2015Guru - Experienced User
OP wants to back up a PC to the NAS, so replicate doesn't apply.
TonV wrote: Did you check out the ReadyNas Replicate tool? That should do the trick too...
tommunday, the throughput of ReadyNAS remote might frustrate you. How much data are you wanting to back up?
