tommunday
May 27, 2015Aspirant
Backup remotely (not over LAN)
Hi, I've had my ReadyNAS a few days and I'm desperately trying to get it backing up remotely (i.e. not from LAN) - ReadyCloud will only backup from USER folder and only to root of NAS (really sophisti...
eton
May 27, 2015Luminary
tommunday wrote: Out of interest, is this a NetGear ReadyNAS thing or would I have to follow the same steps with most makes of NAS? So would Synology's NAS's have a quicker built in solution or just the same sort of thing?
I think the problem is quite universal. Some manufacturers bundle several services into one, like Apples Back to My Mac. Which is a combo of SSH tunnel and dyndns. And you can setup something similar your self (which will give you much more flexibility and control). Instead of VPN, iSCSI over a SSH tunnel might work for you.
