tommunday
May 27, 2015Aspirant
Backup remotely (not over LAN)
Hi, I've had my ReadyNAS a few days and I'm desperately trying to get it backing up remotely (i.e. not from LAN) - ReadyCloud will only backup from USER folder and only to root of NAS (really sophisticated huh?)
If I could map a network drive over the internet that would be ideal and I could run Windows File History as I have done locally before, just pointing the backup at that drive
Having spent a couple of days searching through forums it seemed the only options were either
1) setting up a VPN (which I will persevere if I have to with but seems a little more complicated than I'd hoped for when I purchased the ReadyNAS)
2) Using WebDAV which seems simpler but not very secure
But then a third option seemed to present itself in ReadyNas Remote - by installing this I have the option to get an IP address remotely - 5.xxx.xxx.xxx which I can map a network drive to.
ReadyNas Remote describes itself as a VPN - so would this therefore be a safe and secure method to map a network drive remotely to my NAS?
I haven't seen any other post describe this as a method to map a network drive remotely when it seems the perfect solution - almost seems to good to be true... am I missing something?
- etonLuminary
tommunday wrote: I have some homework planned then, work out what iSCSI over SSH entails!
Thanks Eton, much appreciated
Cool cool. It's a quite generic method. Hopefully it works with your devices. I've used it with great success for other problems. If you need help with setting up dyndns, check out my thread about ddclient.
And it would be nice if you could share your solution when you are done with the task. - tommundayAspirantExcellent, I'll take a look. I've got a busy week or two coming up but when I get round to looking again I'll post any solution I get
- etonLuminaryDid you find this one:
youtube - ReadyNAS iSCSI - setup with OS6 on a ReadyNAS 104 ;)
And when reading about securing iSCSI, I often come across solutions using IPsec.
