realtek1
Jun 07, 2016Apprentice
Backup to ReadyNAS from FTP issue
Hi, Has anyone experienced issues when backing up from a remote FTP server to the ReadyNAS using the ReadyNAS backup page? Basically, if one of the files is over 1GB, the file fails to downlo...
JennC
Jun 07, 2016NETGEAR Employee Retired
Hello realtek1,
For the meantime, can you please try setting up FTP backup job for local share of the NAS as source and another share as destination?
- realtek1Jun 07, 2016Apprentice
Hi,
Yes I did try this before and just tried it again and it does seem to work fine when using the ReadyNAS as an FTP server and then backing up into another folder.
I'm really not sure what could be causing this issue.
To rule out a timeout issue I decreased my router bandwidth to a rediculasly slow amount so it took a very long time but it carried on going until it hit 1GB for an hour or so.
- realtek1Jun 09, 2016Apprentice
Is there anyway I can troubleshoot this issue further? Any logs I can view apart from the ones through the GUI?
Thanks
- JennCJun 09, 2016NETGEAR Employee Retired
Hello realtek1,
Is the FTP server connected to the same network where the NAS is?
What's the model number of the NAS and its FW version?
