realtek1
Jun 07, 2016Apprentice
Backup to ReadyNAS from FTP issue
Hi, Has anyone experienced issues when backing up from a remote FTP server to the ReadyNAS using the ReadyNAS backup page? Basically, if one of the files is over 1GB, the file fails to downlo...
realtek1
Jun 09, 2016Apprentice
At least we have the error now. The command line is actually a frontview command so being run inside a script and you just specify the backup job id to run.
FileZilla does not re-establish a connection from what I can see at that same point.
Perhaps one of the two uses different connection settings.
- StephenBJun 09, 2016Guru - Experienced User
Are you running curl 7.43.0 (enter curl --version to see)
My RN202 has this:
root@RN202:~# curl --version
curl 7.43.0 (arm-unknown-linux-gnueabi) libcurl/7.43.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.25 libssh2/1.4.2Curl 7.43.0 is a bit old (2015 July), but openSSL is current.
