JanSolo
Mar 25, 2016Aspirant
Backup to USB fails due to lack of space; but it's an empty drive and there are no files on it!
I've upgraded my NV+ v1 (4.1.14) with 4x 2TB drives and I ran into the 4k block size problem. So I'm trying to backup my device so I can factory reset it. The current size of the volume is 1.3TB, so...
- Mar 26, 2016
OK, I figured out the multiple partition problem.
When partitioning a drive with Disk Utility on Mac, it creates a HIDDEN FAT32 partition called EFI which is used for some boot info. This EFI partition is confusing RAIDiator and causing it to try and use the small EFI partition instead of the large main one.
Since I'm not booting this drive (it's only for backup), it's safe to remove it. You need to enable a debug option in order to see the partition in Disk Utility. Search google for 'Remove EFI partition on mac' to see how to do it.
Also, I used EXTfs for mac by Paragon Software which allows you to create and mount ext3 partitions on your mac. http://www.paragon-drivers.com/extfs-mac/
Backup job is running now... hopefully it will complete successfully!
JanSolo
Mar 26, 2016Aspirant
I tried to format the drive on my mac... I end up with two partitions like this:
USB Storage Devices
The following USB storage devices are connected.
| Device | Part. | Description | Used | Size | FS | Speed | |||
| USB_HDD_6 | 1 | Voyager S3 [Partition 1] | 0 MB | 196 MB | FAT32 | 480 | Options | Go | |
| 2 | Voyager S3 [Partition 2] | 0 MB | 1862 GB | FAT32 | 480 | Options | Go | ||
The small partition is not big enough to backup to and the large partition is not accessible as a device!
Also, trying to reformat the small partition using raidiator works, but reformatting the big partition causes the http service on the nas to restart.
What is going on? Is there any way to get a USB drive to work? This should be simple, no?
JanSolo
- JanSoloMar 27, 2016Aspirant
Backup is still running 1 day later... It seems awfully slow. My volume is 1300GB in size, but only 400GB has been used on the backup USB drive.
At this rate, it will take another 48 hours to complete the backup! Is that normal? The USB Volume setting state the USB speed is 480MBPS
1.3 TB / 480MBPS is about 45 minutes..... why is it taking 3 days?
Thanks.
Jan.
- StephenBMar 27, 2016Guru - Experienced User
USB 2 runs at 480 megabits, not megabytes. That is also the raw usb bus speed, not the actual disk throughput.
That said, it is normal. Your old NV+ doesn't have good USB performance.
chirpa wrote: The speeds are something close to this:
NTFS = 2.5MB/s
FAT32 = 5MB/s
EXT3 = 10MB/s
EXT2 = 14MB/s10 MB/s should take about two days, not three.
- JanSoloApr 03, 2016Aspirant
Backup was successful.
I reset the device, restored the backup and everything is good.
Thanks for the help, amigos!
