rfplant
Dec 12, 2011Aspirant
BackupExec 2010 R3 Not Seeing Readynas 2100
I've just recently installed a ReadyNas 1500 and then today a ReadyNas 2100 and both are having the same issue, in that Backup Exec 2010 R3 does not see either appliance. Both devices are running the...
bwelmers
Dec 22, 2011Aspirant
Thank you for posting this.
I wish I had read it before I took 6 hours to figure it out.
I also found that if you go to the new backup job
expand domains
expand Microsoft Windows Network and find your ReadyNAS device
select the check box next to it and say yes you trust the device.
the whole reason this is happening is that trust certificates is a new requirement/feature for backup exec 13.0.5204
Now hopefully Netgear will update their documentation some time soon.
expand domains
