Boolnet
Mar 08, 2021Aspirant
Backuping Synology to ReadyNas
Hello Guys, I have a Readynas 4 bay running version 6.10.4. It is running just fine. However, I have a problem when I try to use it to act as the back up of a Synology NAS. I use HyperBacku...
Sandshark
Mar 08, 2021Sensei
uid is User ID and gid is Group ID. I'm not familiar with the backup methods available on Synology, but it looks like you are not using a user and/or group ID that the ReadyNAS recognizes.
It may be easier to configure a "pull" backup from the ReadyNAS instead of doing that "push" from the Synology. That would be especially good if you are only powering the ReadyNAS on for the backup, as it will wait for a completed backup it controls before shutting down, but not an external one.
