rodcrit
Oct 28, 2017Luminary
backups from pc failing after upgrade
after installing the upgrade 6.9.0 my backups from my PC no longer work the backups ( 15 of them ) all start and remain in the " in progress" state. in previous version they remained in the " in...
- Oct 30, 2017
For anybody experiencing an issue with backup jobs remaining in "in progress" on SMB timestamp backup jobs, we have posted a hot-fix to resolve that issue, and your system should be automatically updated some time in the next week. If you'd like the receive the update immediately, you can reboot your NAS and it should be updated within 15 minutes.
RaZorMix
Nov 03, 2017Aspirant
I just checked my ReadyNAS 516 and it is running 6.9.0+4 but Veeam Endpoint still fails with error:
"Incorrect function. Agent failed to process method {ReFs.SetFileIntegrity}."
I even deleted the database and re-created the backup job.
Also have a username and password set in the backup job.
Not sure what else I can do but it's clear this was from the firmware update and the hot fix hasn't worked for me.
