brainbrian
Nov 09, 2014Aspirant
Bad Drive?
Should I assume one of my drives is bad and no reparable if it's showed the drive was failing... so I removed it reinstalled it and it now reads "Newly added disk has failed SMART test. Please check d...
mdgm-ntgr
Nov 09, 2014NETGEAR Employee Retired
If the disk is failing the SMART test it is bad.
Disks can and do fail at any time.
Do you have a backup?
You could connect the disk up to your PC and test it e.g. using SeaTools for SeaGate disks and WD Data LifeGuard Diagnostics for WD disks.
