brainbrian
Nov 09, 2014Aspirant
Bad Drive?
Should I assume one of my drives is bad and no reparable if it's showed the drive was failing... so I removed it reinstalled it and it now reads "Newly added disk has failed SMART test. Please check d...
Nov 09, 2014Guru - Experienced User
The REDs use the same power as the corresponding Greens. There's no reason to consider the Greens for NAS use at all. Reds are set up for NAS use, and have longer warranties.
