JosephAE
Apr 09, 2018Aspirant
Bad Hard Drive Swap
One of the disk drives in my ReadyNAS Pro Business running OS6.9.3 started reporting “Detected high uncorrectable error count: [##] on disk 1”. I bought a new drive. A few weeks later it also reported...
JosephAE
Apr 11, 2018Aspirant
What is the best way to run a S.M.A.R.T. test on the original drive? Is there a way to test the disk using RAIDar from the Admin page? Seagate has a tool call "SeaTools for Windows". Will that work or do I need a different tool or a Seagate legacy tool because the disk is older? I plan to connect the original drive to my Laptop using a USB cable from a SATA to USB adapter. Will that require using a program like Ext2Fsd so as to recognize the drive? Thanks for the help. Just odd that the drive is now reporting that is just fine.
Apr 11, 2018Guru - Experienced User
You can use seatools even though Windows won't recognize the file system on the disk. It will still detect the disk, and let you select it for testing. You won't need ext2fsd or similar packages. This is also the case with Western Digital's lifeguard program.
Start with the short diagnostic test, and if that passes try using the long test.
