FG
Dec 18, 2017Aspirant
Bad OS? RN2120 - Firmware 6.9.1
I recently had some sort of coruption on the NAS causing my to loose all the data. I factory reset NAS and still have some possible bugs left over. Netgear tech suggested to re-install OS, I did that...
- Dec 19, 2017
The apps were associated with a temp volume I created last week, when I factory reset the NAS and then shortly after the reset I deleted the volume. The apps were stuck in the temp volume even thought it was deleted.
A Netgear engineer found the problem yesterday afternoon.
How does a deleted volume hold anything.....its deleted? Not sure that I fully understand what happened, but it is fixed.
Dec 18, 2017Guru - Experienced User
Something isn't quite right, but I wouldn't lose any sleep over it unless there are other symptoms.
FG
Dec 19, 2017Aspirant
