AndrewJohn
Mar 01, 2017Aspirant
Balance failed to start for volume data
This morning, my email notification reported the following error: "Volume: Balance failed to start for volume data." I searched for this message on the community forum, and the documentation,...
- Mar 08, 2017
The info in volume.log is particularly useful if you are interested in analyzing the running time of the various maintenance functions.
The balance completion will also show up in the log page in web ui. If you select the "volume" category you'll get a much shorter list, and it will include both the start and completion of the balance.
Retired_Member
Mar 02, 2017From your screenshot I see, that you have Antivirus service enabled as it is updating the virus definitions. In 6.6.1. AV seems to be a bit unreliable and the potential cause of various issues.
I would disable that service and manually run balance a few minutes after that. If that goes through fine, there is a good chance, that your scheduled balance will also run fine the next time it should kick off anyways.
AndrewJohn
Mar 02, 2017Aspirant
Thank you Roland,
I will try that tonight, or in the morning.
I've read about the unreliableness..., but I am more likely to error on over-protection, than turning it off permanently.
But, for a couple manual rebalances, will do.
thank you,
AJ
- AndrewJohnMar 08, 2017Aspirant
Well, the regularly scheduled Balance seems to have launched.
In my reading threads on this, it appears that there are a number of posts on balance operations going on for weeks...
How will I know that it "completed" the process?
Thank you to all who contributed - much appreciated - we've got Balance Starting..., now how to know it's completed the operation?
- Retired_MemberMar 08, 2017
At the bottom of volume.log you can see the maintenance history, which looks similar to the following:
=== maintenance history ===
device operation start_time end_time result details
data balance 2016-05-26 09:50:10 2016-05-26 09:51:03 completed
data defrag 2016-07-01 17:02:50 2016-07-01 17:04:28 completed
data balance 2016-07-01 17:05:08 2016-07-01 17:05:47 completedYou can download the logfiles as a zip container using the admin website.
- StephenBMar 08, 2017Guru - Experienced User
