Tsp
Aug 14, 2016Aspirant
Balancing does not help with "no space left" despite there is capacity available.
I've run into the issue with ReadyNas 4220. Firmware 6.4.2 There were a lot of posts in community for "no space left" error but none worked for me. # echo Test > /home/admin/test -bash: /home/ad...
sotrack
Aug 14, 2016Luminary
mdgm-ntgr
Aug 14, 2016NETGEAR Employee Retired
Do you have a backup of your data?
Can you delete some files to get volume usage below 80% and then try again?
- TspAug 15, 2016Aspirant
Thanks for reply.
The NAS contains mainly Virtual Machines and we do not backup them.
I’ve freed space to 72% use
# df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 472M 3.3G 13% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 13M 3.9G 1% /run
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
tmpfs 3.9G 0 3.9G 0% /media
/dev/md127 6.5T 4.1T 1.7T 72% /prod
/dev/md127 6.5T 4.1T 1.7T 72% /home
/dev/md127 6.5T 4.1T 1.7T 72% /apps
/dev/md127 6.5T 4.1T 1.7T 72% /run/nfs4/home
/dev/md127 6.5T 4.1T 1.7T 72% /run/nfs4/prod/VMStorage
/dev/md127 6.5T 4.1T 1.7T 72% /run/nfs4/prod/ISO
Balancing made progress to ~70% and failed again with same error.
I’ve got 80% in use back on /prod partition as a result of balancing run and still no luck with “no space left” resolve.
How can I figure out where 600GB disappeared while balancing?
# btrfs filesystem show
Label: '43f63420:root' uuid: 701c9fe6-995a-4572-b360-dd7986123e77
Total devices 1 FS bytes used 447.16MiB
devid 1 size 4.00GiB used 1.53GiB path /dev/md0
Label: '43f63420:prod' uuid: 96799cff-1ad8-4deb-a06b-758cacfea9bd
Total devices 1 FS bytes used 4.04TiB
devid 1 size 6.49TiB used 5.59TiB path /dev/md127
As I understand free workspace is 900GB. Isn't that sufficient?
Is there a way to check what exactly locks the space and which filter to use?
Is that normal that I have to keep more than 1TB free to keep the NAS operational?
Thank you in advance.
