skilke
Sep 25, 2014Aspirant
BASH exploit - Shellshock
Hi
I have a ReadyNas Ultra 2 and it has version 3.1.17 of BASH installed which has a High risk vulnerability.
Can somebody please explain how to patch BASH so that my system is not at risk from this vulnerability. I have tried downloading the source, the patch and patching but 1 file did not patch successfully. If anyone can post some step by step instructions it would be really appreciated (as I am not an expert).
Many thanks
K
Many thanks
K
- SkywalkerNETGEAR ExpertAnyway, if your box is running ReadyNASOS 6.x, the default shell is dash, not bash. So dash is the shell that would get executed from CGIs, rather than bash.
- alexofindyAspirantWhat is the latest on this? Any official word?
I have 3 systems, an NV+, an ultra 6+, and a 316. All run the latest release software. As best I can tell, all three systems are therefore vulnerable.
I have SSH disabled on all 3 systems; it was previously enabled on the 4.x systems with the enablerootssh plugin, but I ran the togglessh plug in, which seems to have disabled remote shell access. (I assume it stops the sshd process) On the 314, I disabled ssh in frontview.
I will probably load the latest beta firmware releases on my NV+ and Ultra 6+; this apparently fixes the bug. Correct?
What about the 314? I don't wish to install the 6.2.0 firmware since it is a major but non-production release, and cannot be downgraded back to 6.1.9. Should I turn on ssh, and use app-get to update bash as others have suggested? Or, is bash not used on the 314, and thus there is no vulnerability.
Or is simply turning off shell access as I described above sufficient.
I do not have any port forwarding enabled on my router, which should be protection enough, but I'd rather have the extra layer of non-vulnerable NAS boxes. - mdgm-ntgrNETGEAR Employee RetiredThe betas for the NV+ and Ultra 6+ address the vulnerability though the chances of the vulnerability being exploited are probably very low.
The 314 is not vulnerable to ShellShock.
6.2.0 should only be installed on non-production systems that are fully backed up. Anyway the current 6.2.0 public beta was built before ShellShock made the news. - dsm1212ApprenticeI'm still running 4.2.25, bit of a chore to update since I'm running virtualbox. Tried updating just bash from 4.2.27 but I get dependency errors. Could i get the 4.2.27 sources posted so that I can update to 4.2.27 and rebuild vbox? The sources link on the beta note is a link to 4.2.23 sources.
steve - schmitzmAspirant@GibsonLP - I understand the latest beta addresses the issue - it would be nice to have confirmation that the beta includes both of the patches to bash though.
Following your writeup, I have managed to cross-build patched bash-3.2 and bash-2.05b binaries - I'll still need to run the testsuites from the source distribution to feel confident enough to replace the old binary. - mdgm-ntgrNETGEAR Employee RetiredYes it does have both patches. You can confirm this by examining the apt-get repository. It should show up in the GPL once there is a production 4.2.27 release.
- wtribaAspirant
schmitzm wrote: @GibsonLP - I understand the latest beta addresses the issue - it would be nice to have confirmation that the beta includes both of the patches to bash though.
I'm definitely interested in the 2.05b binary for my NV+. If/when you're going to make that available, I'd love to get a copy. Thanks! - 0d0aTutorHai, I am using a readynas duo in a lawyers firm, an apt-get install bash doesn't update bash , is this due to the fact the ls is sparc 4.1.13? What can I do about it?
- mdgm-ntgrNETGEAR Employee RetiredYou could try editing the sources list to use the 4.1.14 repository or simply just install the 4.1.14 beta firmware.
- 0d0aTutor
mdgm wrote: You could try editing the sources list to use the 4.1.14 repository or simply just install the 4.1.14 beta firmware.
Changed sources.list to 4.1.14 , that did it!
Should i change back to 4.1.13 or just leave it to 4.1.14?
