tbob
Feb 11, 2017Aspirant
Best practise for ReadyOS 6 full system backup and recovery
Hey community, since I could not find any obvious way how to to a full backup (and recovery of course) of my RN204 (configuration and data), I am reaching out to the community now. Is there a...
Feb 12, 2017Guru - Experienced User
You can't get 100% there on the recovery, since there are some settings that aren't saved in the configuration file. So on the recovery side you will need a procedure.
You might want to create a TimeMachine share, and replace /data/.timemachine with a symbolic link to the share. That should make it easier to backup/restore the timemachine folder.
