Gunplumber
Jan 31, 2022Follower
Best way to acheive backups
Hi Guys Hope i have this in the right section but here goes.. I am trying to work out the best way to store and protect my Buisness data backups. I currently have a Readynas 422 mapped to a loca...
Feb 01, 2022Guru - Experienced User
I have a couple of NAS that back up on a power schedule - including an old Duo. So this is definitely possible. I don't recall off-hand if you can set up a monthly schedule - my Duo is set to weekly. I don't bother to disconnect it from the network, but I have disabled file sharing protocols (SMB, NFS, AFP, etc).
The backup protocol I use is rsync, and that does have options for incremental backup. The first backup will take longer - just let it.
Definitely run the backups on the Duo with the RN422 as the remote source. Then the powerdown schedule will be held off until the backup completes. Try to run the backup off-hours, as that will improve coherency.
