Xaver
Sep 18, 2013Tutor
best way to backup iSCSI?
hi, I have two Pro6 Pioneer one to work with and one as off-site backup? right now i do the backup of all shares with the Frontview backup so the off-site one "pull" to data form the live one wi...
JabbaTheHutt
Sep 27, 2013Tutor
First thing you need to really be careful is rsync is file based. So if your iSCSI LUN gets very large and the data connection drops, you'll have to resend the entire file.
Second is the state of the data/application. As you mentioned if the data is changing at the time of copy/backup then the data may not be in a useful state on the offsite device. How big of an issue this is depends on the data and application. Some applications recovery very well. Some do not.
