maph2880
Nov 30, 2012Follower
Best Way To Migrate Config/Data To New ReadyNas Duo
I have a ReadyNas Duo and just bought a second ReadyNas Duo v2 to replace it.. I have looked in the Netgear KB and around in the forums for any recommendations to migrate configurations (and, if poss...
devilsrear
Nov 30, 2012Aspirant
Hi i did the same thing. However, I only copied the data across.
For the backups I manually reconfigured these - there are some new options on the duov2 that you may want to explore.
The configuration shouldn't take long and if anything it will get you comfortable with the v2 web interface.
