pec967
Jan 14, 2016Luminary
Bit Rot Protection and Home Folders
Can bit rot protection be enabled on Home folders in OS 6.4.x? Unlike shared folders, there is not a check box to enable bit rot protection on Home folders. I replaced a ReadyNAS Duo v1 with a RN...
- Jan 14, 2016The home folders have the bitrot protection option enabled at all times. The "Protection" option that you see for the individual users is the snapshot option for that specific user.
Jan 14, 2016Guru - Experienced User
pec967 wrote:
Thanks for your advice.
Because it will be lots of work to reconfigure all the backup jobs and ReadyNAS Vault backups to use the new shared folder with Bit Rot protection turned on, it would be nice to know if Home folders do indeed support Bit Rot protection. In my set up notes for the RN312, I show that I configured the Home folders with "protection," but I have an additional note that it was not clear what that meant. My assumption at the time was that it meant Bit Rot protection.
I suspect "protection" does mean "bitrot protection" - hopefully Netgear will clarify.
In general I think it's a bit easier to backup/restore shares than it is to backup/restore individual home folders, and the gui won't let you reset permissions. So my overall thinking is that they are more trouble than they are worth for home users. Business use cases are quite different though. OS 6.4.x is better than previous firmware in this regard, but home folders still are harder to manage.
