InteXX
Jan 21, 2015Luminary
BitRot Protection Failure - Anything To Be Done?
12:37:25 AM 01/21/2015 Bit rot protection has detected a silent error within /data/FileHistory/Home/C52893-G/Data/$OF/18143/18144 (2015_01_15 11_11_06 UTC).jpg on /dev/sdc3 and cannot correct the er...
mdgm-ntgr
Jan 21, 2015NETGEAR Employee Retired
If you download your logs what does your initrd.log look like?
When did you enable bit-rot protection on this share?
When did you add this file to the share?
This sounds like it could be a false positive.
