InteXX
Jan 21, 2015Luminary
BitRot Protection Failure - Anything To Be Done?
12:37:25 AM 01/21/2015 Bit rot protection has detected a silent error within /data/FileHistory/Home/C52893-G/Data/$OF/18143/18144 (2015_01_15 11_11_06 UTC).jpg on /dev/sdc3 and cannot correct the er...
InteXX
mdgm wrote: Do you have the kernel log from the time you got the error?
Hm... there's not much there either:
Logs begin at Tue, 20 Jan 2015 23:33:17 -0900, end at Wed, 21 Jan 2015 03:42:24 -0900.
Jan 21 13:24:45 c52893-n kernel: LeafNets: no IPv6 routers present
mdgm wrote: Can you send in your logs (see the Sending Logs link in my sig)?
Sent.
Thanks,
Jeff Bowman
Fairbanks, Alaska
