InteXX
Jan 21, 2015Luminary
BitRot Protection Failure - Anything To Be Done?
12:37:25 AM 01/21/2015 Bit rot protection has detected a silent error within /data/FileHistory/Home/C52893-G/Data/$OF/18143/18144 (2015_01_15 11_11_06 UTC).jpg on /dev/sdc3 and cannot correct the er...
Skywalker
Jan 21, 2015NETGEAR Expert
Are you able to open the file? If so, does it look normal? Fortunately, it should be easy to spot corruption since it's a JPEG image.
