InteXX
Jan 21, 2015Luminary
BitRot Protection Failure - Anything To Be Done?
12:37:25 AM 01/21/2015 Bit rot protection has detected a silent error within /data/FileHistory/Home/C52893-G/Data/$OF/18143/18144 (2015_01_15 11_11_06 UTC).jpg on /dev/sdc3 and cannot correct the er...
InteXX
Jan 22, 2015Luminary
Skywalker wrote: Are you able to open the file? If so, does it look normal? Fortunately, it should be easy to spot corruption since it's a JPEG image.
It's small and heavily pixelated, but here it is just in case: click here.
Spot anything?
Thanks,
Jeff Bowman
Fairbanks, Alaska
