InteXX
Jan 21, 2015Luminary
BitRot Protection Failure - Anything To Be Done?
12:37:25 AM 01/21/2015 Bit rot protection has detected a silent error within /data/FileHistory/Home/C52893-G/Data/$OF/18143/18144 (2015_01_15 11_11_06 UTC).jpg on /dev/sdc3 and cannot correct the er...
Jan 24, 2015Guru - Experienced User
There are two basic scenarios I see:
InteXX wrote: So we seem to have a false positive. Which, as StephenB points out, isn't the best of situations either.
-a "real' false positive (the file was never corrupted)
-a "pseudo" false positive (the file was corrupted, and was properly fixed. But the error message saying "I can't fix it" was still logged).
It might take more reports/additional logging for Netgear to sort it all out. The good news is that whatever went wrong in your case, it did not result in file corruption. And the issue resolved on its own (no more checksum errors, you can access the file, etc).
Of course for us users, the message remains that backups are needed for lots of reasons.
