Squazz
May 22, 2013Aspirant
BitTorrent Sync - How To
This guide is outdated. I havn't got the time to make it up to par Following this guide with above disclaimer is your own responsibility If you havn't read about BT Sync already, do yourself a fav...
fastfwd
Sep 04, 2013Virtuoso
super-poussin wrote: BTsync should start after a reboot , which version of the addons are you using ?
No addon. I am running OS4 on a Pro Pioneer.
super-poussin wrote: that's a bad ID to run it as root :(
Yes, thank you for confirming that it can be run as an unprivileged user. I will modify my script tomorrow.
super-poussin wrote: the addon is here : https://www.dropbox.com/s/djgzikjolykl1 ... 70_all.deb
But only for OS6, correct?
