bwcloud
May 08, 2016Guide
Blinking power light
Hello everyone. This is my first post on here. I've had this ReadyNAS since November 2014 with no problems, but yesterday after I saw the email for needing to migrate the readycloud service to mynetg...
- May 29, 2016
This could relate to some old apps that were installed on the system. I had to manually force apt to do some updates. I also removed a package or two. I also installed the latest version of avplus on the system.
mdgm-ntgr
May 08, 2016NETGEAR Employee Retired
Which firmware did you update from?
How long did you wait for it to boot? If updating from pre-6.4.x firmware the initial boot can take quite some time as the quotas are calculated especially if you have a lot of snapshots.
- bwcloudMay 08, 2016Guide
The firmware was 6.2.x or something like that, IIRC.
