chopin70
Aug 20, 2016Virtuoso
Block DLNA access from a wired device
Hi,
I have my ReadyNAS connected to a Netgear ProSafe Plus switch. The Switch is connected to a Netgear R7000 router.
I also have a snart TV connected by cable to the switch.
I want to stop the TV from reading the DLNA stream from the ReadyNAS
If I block the TV in router access control, only TV access to internet is interrupted. It still can browse the DLNA server
I tried to connect the TV directly to the router instead of the switch, but it is still accessing the DLNA
I didn't try to plug both TV and ReadyNAS directly on the router. However, I don't understand why the Netgear router is still allowing LAN access to the TV
Is there any way with my network setup to disable the wired LAN TV from accessing the ReadyNAS DLNA server ? Unplugging the cable is not a solution in my case, obviously.
I guess the short answer that is the way the access controls in the router work. In any event, generally the traffic between your TV and your NAS won't even reach the router, it will stay on the switch. When I am watching a video saved on my NAS, I can power down the router and the video continues to play normally.
You could connect a second router between the TV and the switch. That would block all services and devices on your network from reaching the TV unless you forward ports - just like your main router.
I'm wondering why you are wanting to do this.
- chopin70Virtuoso
I have a room with smart TV that can be connected to a wall LAN port in the home
I am trying to restrict access to the DLNA server from that device
Are you saying that you have a different DLNA server you want the TV to use? Or that you want to block all DLNA from reaching that TV?
Is it ok completely block the TV from accessing any device on your local network (limiting it to internet only)?
Are you wanting to block the service 24x7, or only for specific hours?
Presumably there are other devices that you want to allow access to ReadyDLNA?
I am guessing that the goal here is parental controls - if not, why are you wanting to block access?
