freshd
Apr 01, 2014Aspirant
boot issue after psu blow out #23003280
well the long story is that I came home to find the nv+ (v1) off, and the psu was dead so I managed to get it replaced for free under that old known issue (even though I replaced it once back then - s...
Apr 02, 2014Guru - Experienced User
If the NAS is also an NV+ v1 you can migrate the disks (assuming they are intact of course).
If the firmware in the NAS flash doesn't match the version on the drives, then the NAS will upgrade (or downgrade) the OS partition. So ideally you'd initially start the system with a scratch disk (only) and then install the same firmware version you had on your old one. Then power it down, and install the old disks (preserving the slot numbers).
After it is running again, back it up!
