freshd
Apr 01, 2014Aspirant
boot issue after psu blow out #23003280
well the long story is that I came home to find the nv+ (v1) off, and the psu was dead so I managed to get it replaced for free under that old known issue (even though I replaced it once back then - s...
Apr 02, 2014Guru - Experienced User
I'm not a mac guy, so I can't help you there.
If you are using xraid with 4 drives installed, then you would need at least three of them simultaneously mounted to retrieve your data. In your NAS, the data is spread across drives 1-3, and drive 4 is a "parity" disk used to recover missing data.
