Nr4
May 26, 2017Aspirant
Broken Rn Pro 4 after trying to update to 6.7.3 - cycle: startup faild - Retry startup 90 %
Hi, because of SambaCry I wantet to update to 6.7.3. The update failed and the Box was still on 6.7.1. So I gave it a second try. This time the box was several times trying to updat with some reboot...
- May 26, 2017
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4.
mdgm-ntgr
May 26, 2017NETGEAR Employee Retired
I've sent you a PM. You'll probably need to force power off the system to do the shutdown required before the steps I gave you.
- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
