edkedk
Jul 20, 2016Tutor
btrfs_merge_bio_hook+a0 error, recovery possible?
Hi, I have a ReadyNAS 204 with the btrfs_merge_bio_hook+a0 error. After reboot I can ssh into the box, but the web interface does not load and the data volume is not mounted. Output of cat /p...
- Aug 01, 2016
Eventually I used --path-regex to restore specific directories and it worked fine. Seems that everything I wanted was copied.
davexyz
Jul 21, 2016Aspirant
This can be recovered (data recovery is dependent on circumstances) using 3rd party software and a Windows or linux pc. Transferring the discs to the PC or an esata box and the software reconstructs the volume fo to be trnsferred of the volume onto your recovery drives
A search on this forum should indicate the software that could be used.
edkedk
Jul 21, 2016Tutor
Could you link a thread that mentions possible recovery software?
