Hans_Kusters
Dec 27, 2016Aspirant
btrfs search forward +2d4 error on RN204
For few weeks I get an "btrfs search forward +2d4" error in my RN204 status window and after that the NAS is inaccesable by network PC's and no longer responsive even does not react to pushing power ...
Dec 31, 2016Guru - Experienced User
Hans_Kusters wrote:
Guess I am correct I did skip the mandatory 6.5.2 version. Guess I have to do factory reset. Or is there other option?
First, I don't think upgrading from 6.5.1 to 6.6.0 caused this problem.
If you have a full backup, you could proceed with the factory reset. But if there's data on the NAS you'd like to back up, then wait for mdgm to get back to you. Or use paid support.
Hans_Kusters
Jan 02, 2017Aspirant
Still waiting for analysis of my log files. Meanwhile did some more digging. Ran diagnose utility from Raidar on my NAS.
Got long list of errors (see below) that seem to point at faulty drive. Anyone know what it means and what drive is affected.
Any clue if drive is defective or if reformating would restore/repair drive?
Hans
---copy of diagnostics result----
Successfully completed diagnostics System Logs
- 2017-01-02 09:10:03: BTRFS: error (device md127) in btrfs_commit_transaction:2083: errno=-5 IO failure (Error while writing out transaction)
- 2017-01-02 09:07:25: BTRFS critical (device md127): unable to find logical 1444213391360 len 4096
- 2017-01-02 09:07:24: BTRFS critical (device md127): unable to find logical 1444213391360 len 4096
- 2017-01-02 09:06:44: BTRFS critical (device md127): unable to find logical 1444213555200 len 4096
- 2017-01-02 09:06:43: BTRFS critical (device md127): unable to find logical 1444213555200 len 4096
- 2017-01-02 09:06:35: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 09:06:34: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 09:06:33: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 09:06:32: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 09:06:31: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 09:06:30: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 09:06:29: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 09:06:28: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
list continues but deleted middle part, guess you get the idea
- 2017-01-02 07:59:13: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 07:59:12: BTRFS critical (device md127): unable to find logical 1444213563392 len 4096
- 2017-01-02 07:59:11: BTRFS critical (device md127): unable to find logical 1444213563392 len 4096
- 2017-01-02 07:59:10: BTRFS critical (device md127): unable to find logical 1444213563392 len 4096
- 2017-01-02 07:59:09: BTRFS critical (device md127): unable to find logical 1444213563392 len 4096
- 2017-01-02 07:59:08: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 07:59:07: BTRFS critical (device md127): unable to find logical 1444213571584 len 4096
- 2017-01-02 07:59:06: BTRFS critical (device md127): unable to find logical 1444213579776 len 4096
- FramerVJan 02, 2017NETGEAR Employee Retired
Hi Hans_Kusters,
The error seems to be pointing to your data volume.
On the logs the got, can you look at the mdstat and disk_info?
On the mdstat look for something similar like:
md127 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[1]
2915732352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
On the disk_info, look out for:
1. ATA Error.
2. Reallocated Sectors.
3. Current Pending Sector Count.
4. Uncorrectable Sector Count.
You could also PM mdgm regarding the system logs update.
- Hans_KustersJan 03, 2017Aspirant
FramerV
Thanks for helping. No reply from mdgm on my logs. No clue how to reach him by PM.
Yes as you suspected there is these lines in mdstat log
17567012352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid6 sda2[0] sdd2[3] sdc2[2] sdb2[1]
1047424 blocks super 1.2 level 6, 64k chunk, algorithm 2 [4/4] [UUUU]
=====But no clue what this means or how to repair it.
In diskinfo.log there is noting with regard to (S)ATA errors or Sector problems
So unlikely the problem lies in errors on disk.
As said before send logs to mdgm a week ago and waiting for mdgm to contact me as I have no clue on how to contact him.
Hans
FramerV
And yes, as you suspected there is similar lines in mdstat log
They read:
1047424 blocks super 1.2 level 6, 64k chunk, algorithm 2 [4/4] [UUUU]But no clue what this means or how to repair it.
Hans
- StephenBJan 03, 2017Guru - Experienced User
PM - "private message" Use the messages link in the upper right corner of the forum, addressing the message to mdgm.
