MikeC1
Oct 07, 2021Tutor
btrfs_sync_log+840 problem
Hi, My RN104 has started failing with the message "btrfs_sync_log+840" on the front LCD. The device is fitted with 4 x 4TB disks and is running 6.10.5 hotfix. It has worked problem free for sev...
Apr 08, 2024Guru - Experienced User
Which means it is crashing at that location.
The best solution (though time consuming) is to backup all the data and do a factory default. You'll then need to reconfigure the NAS and restore data from backup.
Do you have any apps? If you do, this approach would also require you to reinstall them. This isn't easy, as the version of Debian the NAS is running has been retired. But there are instructions here on config changes you need to make.
