chopin70's avatar
chopin70
Virtuoso
Jul 15, 2017
Bug FW 6.7.5 Final: Balance ends immeadiately
Hi,   I manually startedcBalance, and it immeadiately completed:   Log messages: Sat Jul 15 2017 23:25:22   Volume: Balance complete for volume data. Sat Jul 15 2017 23:25:17   Volume:...
  • Hopchen's avatar
    Hopchen
    Jul 17, 2017
    Yup, you can see by the dmesg output that the NAS balanced a few chunks and thus it was not failing. At the same time your NAS is perfectly well balanced already, so it is no suprise then that a balance only takes a few seconds to run on your system.
    Balance is not the same as say, a defrag or scrub. If there is hardly anything to balance - it will be super fast. But that is good that you have a well balanced volume!
ProSupport for Business
