quickly_now
Nov 01, 2015Apprentice
Bug Report: Firmware 6.4.0 Rsync Timeout
Hello Really one for Netgear support (posted here as I don't know how else to submit it). I use rsync to backup my ReadyNas 314 to an external eSATA drive. I had similar issues to others ...
quickly_now
Nov 06, 2015Apprentice
More information:
Using ps I was able to get the command line, and then ran rsync to do my eSata backup, omitting the --timeout=30 option.
All works fine.
So the command line I used was:
rsync -v -8 --recursive --links --times --omit-dir-times --omit-link-times --devices --specials --modify-window=1 --delete --owner --group --acls /tmp/10219/data localhost::ESATA_HDD_4/
This works fine.
Suggestion: please allow us to change the timeout period. --timeout=30 is too short.
BrianL2
Nov 08, 2015NETGEAR Employee Retired
Hi quickly_now,
We will check on this one. For the meantime, check if the latest Beta Firmware (ReadyNASOS 6.4.1-T29 (Beta 2)) works fine.
Kind regards,
BrianL
NETGEAR Community Team
- quickly_nowNov 08, 2015Apprentice
Have loaded that beta.
No joy.
--timeout=30 still passed on the command line.
Running rsync without that, its all Ok.
New beta does not solve it.
- BrianL2Nov 08, 2015NETGEAR Employee Retired
Hi quickly_now,
We will further check this and keep you posted for updates.
Kind regards,
BrianL
NETGEAR Community Team - ernst_stuckiNov 09, 2015Aspirant
I have installed the 6.4 T29-version. Backup still fails. The problem becomes really urgent, because the NAS gets dramatically slower (as I mentioned before). It's no longer possible to work in a normal way. Sometimes I have to wait 20s or more to get the content of a network folder. Please help!
- BrianL2Nov 09, 2015NETGEAR Employee Retired
Hi ernst_stucki,
Have you toggled off/on the Rsync service of the ReadyNAS? Let me know if doing this helps.
Kind regards,
BrianL
