GJSchaller
May 07, 2019Guide
Call to undefined function curl_init() on 6.10.0
I recently installed Nextcloud on my ReadyNAS, which is running 6.10.0. The installer package installs Nextcloud 13.0.5, which is an older version. When I run the updater from the command line, I g...
May 07, 2019Guru - Experienced User
There is a huge issue with php and 6.10.0. I suggest waiting for WhoCares_ to resolve it. Then perhaps purchase the fixed app from http://rnxtras.com
He gives a brief explanation of the issue there.
GJSchaller
May 07, 2019Guide
I'm aware, and have been monitoring, but would like to patch up my Nextcloud while I can rather than leave an upatched system facing the internet.
If we can get curl_init working, the update will be simple.
