ScuseMe1
Jul 31, 2014Aspirant
Can a "downgrade" to a smaller drive cause my NV+ problems ?
Hi, In fixing my previous problems with my NV+ firmware freezes, I replaced the 1st bad drive with a good one I had lying around. It seemed to work just fine, with the sync of the replaced drive ju...
Marto731
Mike,
You have not advised the TeraByte size of disks you are using.
If you are having on-going NV+ v1 problems, can you open a support ticket, and send NAS logs to the agent.
It is good practice to have important data backed up. :wink:
Regarding inserting a smaller disk, this is something we advise against, and messes up the RAID structure.
More detail here http://www.readynas.com/forum/viewtopic.php?f=66&t=77126&p=429490&hilit=smaller#p429490
Regards, Marto
Regards, Marto
