ScuseMe1
Jul 31, 2014Aspirant
Can a "downgrade" to a smaller drive cause my NV+ problems ?
Hi, In fixing my previous problems with my NV+ firmware freezes, I replaced the 1st bad drive with a good one I had lying around. It seemed to work just fine, with the sync of the replaced drive ju...
ScuseMe1
Hi marto73,
The original tb size was
1: 1 tb
2: 0.5 tb
3: 0.5 tb
4: 0.5 tb
the 1 tb drive was the 1st 1 tb I was planning to use to upgrade all drives to 1 tb. But since the 1 tb drive broke ater 1 year (Seagate Barracuda), I put my old 0.5 tb drive back in to replace the 1 tb broken drive.
Unfortunately, I can't get to the logs, since the front panel says:
Booting
Disk 1 sync
RAIDar came up once and showed the same configuration as the LCD panel said, but RAIDar hasn't since come back to login.
I have another 1 tb ext drive that I had the NV+ saving to, but it's in EXT3 format. In addition, I'm not sure when the firmware problem started, because lately I've been using iTunes and iTunes Match, so I'm not sure of the integrity of the backup.
Thank you for the assistance. Please advise me what is the next logical course of action.
Mike
1: 1 tb
2: 0.5 tb
3: 0.5 tb
4: 0.5 tb
Booting
Disk 1 sync
Mike
