ScuseMe1
Jul 31, 2014Aspirant
Can a "downgrade" to a smaller drive cause my NV+ problems ?
Hi, In fixing my previous problems with my NV+ firmware freezes, I replaced the 1st bad drive with a good one I had lying around. It seemed to work just fine, with the sync of the replaced drive ju...
Jul 31, 2014Guru - Experienced User
I'd shut down, remove drive 1, and reboot. The system should then start (though degraded). Then do a backup.
After that I'd run diags (seatools, lifeguard) on the original drive 1.
