roveer1
Sep 24, 2017Guide
Can I add a 10gb NIC to my ReadyNAS 6 Pro?
Is it possible to upgrade a RNDP6620D-200NAS with a 10gb NIC?
DaneA
Sep 28, 2017NETGEAR Employee Retired
Hi roveer1,
Yes, you are right. 10Gbps LAN ports are supported on both RN526x and RN626x series models. Kindly check the data sheet below for more information:
ReadyNAS 520/620 Series Data Sheet
DaneA
NETGEAR Community Team
DaneA
Oct 01, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
