Laudz
Feb 18, 2018Aspirant
Can I move drives between an ARM based RN104 to an Intel ReadyNAS unit?
Hi, I've been using a very dependable Ultra4 unit for years until it recently ran out of space. I purchased a RN104 with 4x4TB drives as a replacement. The transfer of data took a very long time and...
- Feb 18, 2018
Hi Laudz
Welcome to the Community!
Migrating a ReadyNAS OS6 unit to another OS6 Unit is possible but since you are using an ARM based unit and planning to transfer to an Intel based model then possibly the Apps installed will be the one not working. At least uninstall the Apps first then just install the x86 version of the App once the volume has been migrated.
A full backup of your data or if you have a regular backup scheduled is always recommended.
Please see this article.
Hope this helps!
Regards
Marc_V
Feb 18, 2018NETGEAR Employee Retired
Hi Laudz
Hope this helps!
Regards
- LaudzFeb 18, 2018Aspirant
Thanks for the info Mark_V.
I have no apps installed on the RN104, so I will just backup the data and move the drives across.
I thought it might be a bit more complicated as I thought the OS was stored on the drives boot partition, and this would be an ARM binary. Not sure how the ReadyNAS units running Intel firmware understand and use the ARM ReadyOS6 binary.
Good to know that the Netgear software engineering team have made this seemless.
- StephenBFeb 19, 2018Guru - Experienced User
Laudz wrote:
Not sure how the ReadyNAS units running Intel firmware understand and use the ARM ReadyOS6 binary. ... Good to know that the Netgear software engineering team have made this seamless.
It's actually a bit more complicated than that - x86 OS-6 NAS use btrfs for the OS partition, and the arm units use ext.
Both boot loaders see that the disks have the "wrong" OS installed, and both can convert the OS to the other platform type (and file system) while preserving the settings. Netgear must have put quite a bit of effort into making that seamless - I agree it is great that they did.
Handling the apps would be impractical, since they aren't developed by Netgear, and several are only available on one platform.
- mdgm-ntgrFeb 19, 2018NETGEAR Employee Retired
Actually the OS partition will stay as EXT if you move the disks from ARM to x86. Of course if you were to do a factory reset (wipes all data, settings, everything) that would change, but you shouldn't need to do that.
