b_i_l_l_y
Nov 15, 2023Aspirant
Can I upgrade an old ReadyNas Duo RND2000 v1?
I have an old ReadyNas Duo RND2000 v1 (RAIDiator 4.1.16) that seems to work ok, but due to the age of the OS I cannot connect via Windows (SMB 1 issue) plus I would like to upgrade to whatever I can ...
Sandshark
Nov 15, 2023Sensei
Definite no on both. It's ancient SPARC processor just isn't supported by anything. You didn't ask, but you also can't update to ReadyNASOS 5.x.
If you are using a Windows computer, you can enable SMB1 on it. AFAIK, you can't do so on a Mac, but you can use AFP (at least for now).
But you'll also run into a problem because it's only got TLS V1.0, so modern browsers can't connect with the GUI. There are work-arounds posted elsewhere in the forum.
IMHO, since you're not already using it and want to extend that use, those limitations, it's slowness, and its limitation to 2TB drives should probably make you consider moving to a newer NAS. But since Netgear is no longer offering new ones, you'll have to go to another brand.
- b_i_l_l_yNov 16, 2023Aspirant
Thanks for the info.
Yes I do have a windows machine and I also have x2 other Synology's just wanted to reuse/recycle this old tech rather than throwing it.
I can access the 'admin' page using an old copy of firefox (portable) and I do have rsync enabled so I can use this protocol instead but I used the nas previously and it was 90% full so I need clear some data from it ... I did this by enabling SSH then using FTP on port 22 to access the drives and clear the data ... now hopefully I can use it as a destination using rsync.
The RND currently has x2 1TB drives can I remove the RAID so I have 2TB of storage ... or does this mean factory resetting?
- StephenBNov 16, 2023Guru - Experienced User
This would require a factory reset, and switching to FlexRAID. I suggest using two 2 TB volumes instead of spanning both disks with RAID-0. RAID-0 is very fragile, so if either disk fails you lose the entire volume.
Duo v1 manuals are here:
- https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
- https://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf
The final firmware release was 4.1.16
If I recall correctly, you will need RAIDar 4.3.8 to switch to FlexRAID
Installation will require Java 8 - this version will work:
Current firefox works, if you change the TLS configuration to allow TLS 1.0.
You can also patch the NAS using ssh to allow http connections to the frontview. More information on that is here:
Enabling ssh requires installing this add-on:
Thank you for the valuable info, I will give these suggestions a try 👍
