b_i_l_l_y
Nov 15, 2023Aspirant
Can I upgrade an old ReadyNas Duo RND2000 v1?
I have an old ReadyNas Duo RND2000 v1 (RAIDiator 4.1.16) that seems to work ok, but due to the age of the OS I cannot connect via Windows (SMB 1 issue) plus I would like to upgrade to whatever I can ...
b_i_l_l_y
Nov 16, 2023Aspirant
Thanks for the info.
Yes I do have a windows machine and I also have x2 other Synology's just wanted to reuse/recycle this old tech rather than throwing it.
I can access the 'admin' page using an old copy of firefox (portable) and I do have rsync enabled so I can use this protocol instead but I used the nas previously and it was 90% full so I need clear some data from it ... I did this by enabling SSH then using FTP on port 22 to access the drives and clear the data ... now hopefully I can use it as a destination using rsync.
The RND currently has x2 1TB drives can I remove the RAID so I have 2TB of storage ... or does this mean factory resetting?
Nov 16, 2023Guru - Experienced User
This would require a factory reset, and switching to FlexRAID. I suggest using two 2 TB volumes instead of spanning both disks with RAID-0. RAID-0 is very fragile, so if either disk fails you lose the entire volume.
Duo v1 manuals are here:
- https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
- https://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf
The final firmware release was 4.1.16
If I recall correctly, you will need RAIDar 4.3.8 to switch to FlexRAID
Installation will require Java 8 - this version will work:
Current firefox works, if you change the TLS configuration to allow TLS 1.0.
You can also patch the NAS using ssh to allow http connections to the frontview. More information on that is here:
Enabling ssh requires installing this add-on:
- b_i_l_l_yNov 16, 2023Aspirant
Thank you for the valuable info, I will give these suggestions a try đ
- SandsharkNov 16, 2023Sensei
Those old NAS are still useful, especially as backup devices in the home where speed is not an issue and the fear of compromise is less. The limitation to 2TB drives does drive many away, though. Netgear did build them like a tank, so they last a long time (save maybe the power brick, which is easily replaced).
- StephenBNov 16, 2023Guru - Experienced User
Agreed. My own Duo v1 (and and NV+ v1) are both still in service as secondary backups. SMB, etc are not enabled, just rsync. They are on a power schedule, and so are essentially air-gapped most of the time.
But the 2 TB limitation definitely gets in the way, as both together don't have enough capacity to back up all my data.
