b_i_l_l_y
Nov 15, 2023Aspirant
Can I upgrade an old ReadyNas Duo RND2000 v1?
I have an old ReadyNas Duo RND2000 v1 (RAIDiator 4.1.16) that seems to work ok, but due to the age of the OS I cannot connect via Windows (SMB 1 issue) plus I would like to upgrade to whatever I can ...
b_i_l_l_y
Nov 16, 2023Aspirant
Thank you for the valuable info, I will give these suggestions a try đ
Sandshark
Nov 16, 2023Sensei
Those old NAS are still useful, especially as backup devices in the home where speed is not an issue and the fear of compromise is less. The limitation to 2TB drives does drive many away, though. Netgear did build them like a tank, so they last a long time (save maybe the power brick, which is easily replaced).
- StephenBNov 16, 2023Guru - Experienced User
Agreed. My own Duo v1 (and and NV+ v1) are both still in service as secondary backups. SMB, etc are not enabled, just rsync. They are on a power schedule, and so are essentially air-gapped most of the time.
But the 2 TB limitation definitely gets in the way, as both together don't have enough capacity to back up all my data.
