ruscoep
Apr 15, 2017Aspirant
Can I upgrade from Radiator 4.1.15 to 5.3.12?
Hi there, I have downloaded V5.3.12 but do not seem to be able to upgrade it using Raidar Local upgrade option. If I try to upgrade using Frontview it tells me that V4.1.15 is the latest version. ...
- Apr 15, 2017If your NAS is running 4.1.15, it's a "SPARC" or "4.1" generation. It can only run 4.1 firmwares. You cannot install a 5.x firmware.
jak0lantash
Apr 15, 2017Mentor
ruscoep
Apr 16, 2017Aspirant
Thanks, thought that might be the case. So the V2 can be either SPARC or ARM architecture?
