yahtzee
May 12, 2019Tutor
can not delete readynas 102 snapshots
I can not delete snapshots. They are filling up most of the hard drive. I can see them when I turn on the viewing of the snapshopt folder. They go back 4 years and it seems they have never been au...
- May 13, 2019
First of all, if you use the SMART snapshots, the monthly snapshots are never deleted. So I always recommend using Custom snapshots instead - where you can set retention.
On the space reclamation - deleting a couple of snapshots often won't free up space. Generally you get the most space gain by deleting the oldest snapshots first. Often you need to run a balance afterwards to fully reclaim the space.
You could try deleting them all using ssh. Though since your volume is very old, I suggest backing up your data, doing a factory reset, reconfiguring the NAS, and restoring the data from the backup. You'll find that not only solves the snapshot issue, it should also improve your overall system performance. Netgear has improved the btrfs configuration over of the years, but those improvements only take hold on a new volume.
May 13, 2019Guru - Experienced User
- yahtzeeMay 14, 2019Tutor
I assume the proceedure for doing a Factory Reset would be -
Backup data (I have a HD attached to the front USB)
Do Reset
Update firmware
Recreate Shares and folders
Restore data
Recreate users and permissions
Recreate backups
Where do I find Custom snapshots and disable Smart snapshots?
- StephenBMay 15, 2019Guru - Experienced User
Yes.
Just go to the settings for each share, and navigate to snapshot settings. There's a toggle at the top of the page to switch between Smart snapshots and Custom snapshots.
- yahtzeeMay 20, 2019TutorThanks. Followed you advice to reset and restore. Everything seems ok now. Set custom snapshots.
