NickKhutorn
Dec 04, 2022Aspirant
Can not login default admin
Hello. ReadyNAS 314/.. My problem. After default reset cann't login as an admin. Trying admin - /password/1234/admin ...other Previous pass doesn't work. The defaults installed, its works..but i ...
- Dec 05, 2022
took off all hard's and format them.
Placed again, then RN get in safe mod, where I get whith standart pass
Now its resync data/
Dont know what will be after rebooting///10h
Dec 04, 2022Guru - Experienced User
NickKhutorn wrote:ReadyNAS 314/.. My problem. After default reset cann't login as an admin.
The default admin password for OS-6 systems is password. So try that one again.
Make sure you are browsing to https://nas-ip-address/admin (using the real NAS ip address or NAS name). The /admin part matters.
- NickKhutornDec 04, 2022Aspirant
FW: V6.1.6
- StephenBDec 04, 2022Guru - Experienced User
NickKhutorn wrote:
FW: V6.1.6
Wow, very ancient (Feb 2014). Definitely should be upgraded.
I suggest trying another OS reinstall.
